Cooler for cpu overclocking
Solved by Trulop,
20 minutes ago, Sentry Man said:Hello guys,
I have recently bought an i5 8600k and would like to know what aio liquid cooler I should use for decent overclocking.
My build:
i5 8600k
Gigabyte z370 aorus ultra gaming
Cooler Master Mastercase h500p
Corsair rm750x
Thanks
Corsair H110, Corsair H115, NZXT Kraken X62, Fractal design S24 or S36 (depending on if you want a dual or triple RAD and can fit it) Ive heard some like the cryorig A80, Those are some that would be great. Should be able to get your CPU to the max OC it can go (average are getting near the 5-5.2GHz range)
