If you're gaming, what games and what resolution.
If you're working on it, what programs, and what kind of work.
How big does the PC have to be? This means do you want a large-ish desktop or a little box you can fit under the table.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
First, you need to figure out what you want out of the machine. Is it purely for gaming? is it an all around pc for gaming/heavy tasks like editing? or is it a workstation. Depending on your needs will depend on what you essentially need for the PC. Then factor in size. you can build micro PC's for limited space, or a big MID ATX case for all the cool looking asthetic and great airflow. Give us some details on exactly what you would like out of it in the long run, and we can fine tune some options for you.
