Hey guys,
You have been there for me in the past. Now I need support once again. I have a white fence around my yard and my son wants a projecter screen on the fence for his birthday. Which is way cheaper I think than spending $$$ at a activity place. I'm on a budget about 150 or so. I have an apple tv and a ps3 in case I need to stream or buy a DVD. Not sure how a projector works with sound etc. So please any tips and tricks and models of projectors etc. Thank you in advanced.
https://linustechtips.com/topic/852737-projector-help/
So you don't own an projector or so?
Soudwise projector often have integrated Speakers with 5 or 10 watts but they suck. You then would need to output the sound to an PA System or so.
But another factor is daylight. If you want to use the projector outside (at least when it's not night/dark) you are pretty doomed with an consumer device. You would need something with 10000+ ANSI Lumens. Such pro projectors cost several thousand dollars so you could maybe rent one but that would be over your budget I think. You can hire such an projector at the company where I am working at but this costs 400€-isch a day or so...
Either move the projector inside or placing an matte screen outside (what also won't be that good in terms of reflection and viewability) would be the best solution.
Hope this gave you some insight. Feel free to ask if you have other questions ;)
Main Rig
CPU - i7 6700 | RAM - 16GB (2x8GB) G.Skill, 16GB (2x8GB) Crucial OEM | GPU - MSI GTX 980 Gaming | PSU - Cooler Master G450M | Storage - 1x 256GB Samsung SM951 (NVMe)(System), 2x 500GB Samsung 860 EVO (Striped) | Case - Fractal Design Define R5 (with TG side Panel) | OS - Windows 10 Pro
NAS / Docker Host
CPU - Xeon E3-1220v3 | RAM - 16GB (2x8GB) Kingston ECC | PSU - Enermax Revolution SFX 550W | Storage - 3x 4TB WD Red, 1x 2TB WD Red, 4x 3TB Seagate Constellation, 2x 250GB Samsung 850 EVO (Cache) | Case - AVID Unity Media Engine (3U Rackmount) | OS - UnRAID OS Pro
VM Host
CPU - Xeon E3-1246v3 | RAM - 32GB (4x8GB) Samsung ECC | PSU - Enermax Revolution SFX 550W | Storage - 2x 512GB Samsung 860 Pro (System / "Fast" VM's), 4x 500GB HGST (RAID 10) | Case - Avid Unity MediArray XT (3U Rackmount) | OS - Windows Server 2019 Datacenter
Notebooks
Fujitsu Lifebook E756CPU - i5 6200U | RAM - 8GB DDR4 OEM | GPU - Intel HD 520  | Storage - 250GB Crucial MX500 | OS - Windows 10 Pro
Apple MacBook Pro Mid 2015 | CPU - i7 4770HQ | RAM - 16GB | GPU - Intel Iris Pro | Storage - 512GB Toshiba XG4 NVMe | OS - macOS 10.15.1
https://linustechtips.com/topic/852737-projector-help/#findComment-10623587
