My friend is experiencing a very strange problem with his machine. Basically, his keyboard and mouse gets stuck but the game still goes on, 3 beeps occur and then inputs return. The video link below has it documented
https://youtu.be/I89WrVQdxMs
  • CPU:  AMD Ryzen 7 7800X3D
  • Motherboard:  MSI PRO B650M-A WiFi
  • RAM:  G.Skill Trident Z5 RGB 32GB (2 x 16GB) DDR5 Memory @ 6000MHz
  • Graphics:  Colorful iGame GeForce RTX 3070 Ti Ultra W OC 8G-V
  • StorageKingston KC3000 2TB M.2 PCIe NVMe Gen4 SSD; Seagate Barracuda 2TB Hard Disk Drive @ 7200rpm
  • PSU:  Cooler Master V1000 1000W 80+ Gold
  • Case: Corsair 4000D Airflow
  • Keyboard: Cooler Master CK550 RGB Mechanical Gaming Keyboard w/Gateron Red switches
  • Mouse: Glorious Model O- Wireless @ 1600dpi, 1000Hz
  • DAC: JDS Labs OL DAC
  • AMP: JDS Labs O2 AMP
  • Headphones: Hifiman HE-400I w/ZMF Ori Lambskin pads
  • Soundbar: Creative Sound BlasterX Katana
  • Monitor 1: BenQ EL2870U @ 3840 x 2160, 60Hz
  • Monitor 2ASUS Predator XB252Q @ 1920 x 1080, 240Hz
  • Monitor 3AOC G2460 PQU @ 1080 x 1920, 144Hz
https://linustechtips.com/topic/851691-keyboard-and-mouse-input-stuck/
Don't know what it would be, my first guess would be the wire or bad contact in the port, but honestly I have no idea.
13 hours ago, johnukguy said:
Has he tried reinstalling the USB drivers for his system? There is also a problem with some Logitech mice that does this, that's hardware related and they'll usually send you a replacement if you contact them.
He is using a Zowie FK1 mouse so no it's not Logitech and he has already installed the USB drivers
