Could be.
(DISCLAIMER: I've never heard of this app at all)
https://linustechtips.com/topic/851142-i-need-some-help/#findComment-10607721
Quote
Q: Application installs correct but the voice is not changed. What can I do?
A: Go to audio settings, recording devices. Right click on microphone ->Properties. If the dialog has an "Enhancements" tab, go to that tab. Make sure the "Disable all enhancements" check box is unchecked, even if you don't use any of the enhancements in the list. If the dialog does not have an "Enhancements" tab, go to the "Advanced" tab. Make sure the "Enable audio enhancements" check box is checked.
There are four different installation modes ( Clownfish's Setup menu ) - try each of them and check if this will help you ( remove device, change mode and install device)
https://linustechtips.com/topic/851142-i-need-some-help/#findComment-10607738
