Hello, for the past two weeks my internet has been terrible. I have done everything from power cycles to changing hardware. I experience packet loss and have high ping a majority of the time. I called Suddenlink (the main(only) provider of internet in my city) and they said that the line to our house looked fine. Recently some new apartments were built and they use Suddenlink. Can these new apartments be causing my internet to experience difficulties? The Suddenlink engineering that came by suggested upgrading speed. Would this solve my problems?
https://linustechtips.com/topic/850816-internet-help/
Wifi? Yes? There's your problem.
On the off chance that the answer is somehow no, please tell us your network layout.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/850816-internet-help/#findComment-10603740
I have a coax line going into my apartment, from there it goes into a modem/router combo from Suddenlink (had my own but swapped out to see if my hardware was bad) into ethernet to the computer.
https://linustechtips.com/topic/850816-internet-help/#findComment-10603747
What model is the modem/router combo? The ones ISPs usually give out are crap. And what of your own did you swap it out with?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/850816-internet-help/#findComment-10603756
2 minutes ago, SheepForest said:
I have currently a Hitron Technologies CGN, but before I had a basic Doscis 3.0 Modem and and Cisco Linksys E2500
What speed do you currently have?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/850816-internet-help/#findComment-10603781
30 down, 1 up
What are you using to measure ping/packet loss?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/850816-internet-help/#findComment-10603791
9 minutes ago, SheepForest said:
I'll just ping google.com over a period of like 3 minutes and other sites as well.
In that case this is very strange. As long as nothing else is seriously using the network I don't see why you are having these issues.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/850816-internet-help/#findComment-10603860
This is my traceroute
Tracing route to google.com [216.58.218.142]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  suddenlink.net [192.168.0.1]
  2     *        *        *     Request timed out.
  3    21 ms    11 ms    15 ms  173-219-229-76.suddenlink.net [173.219.229.76]
  4    14 ms    16 ms    18 ms  173-219-152-250.suddenlink.net [173.219.152.250]
  5    14 ms    17 ms    12 ms  72.14.202.216
  6     *        *        *     Request timed out.
  7    18 ms    14 ms    16 ms  108.170.238.227
  8    14 ms    12 ms    20 ms  dfw25s08-in-f14.1e100.net [216.58.218.142]
Trace complete.
https://linustechtips.com/topic/850816-internet-help/#findComment-10603892
