Yo, so I'm overclocking my monitor right now just for the hell of it and when I create a custom resolution and successfully apply it, the new refresh rate doesn't show up in the advanced settings of my display. Any ideas?
Thanks
We're all dying slowly
Pentium G3258 3.2 ghz / ECS z97 pk MOBO / Intel Stock Cooler / R9 290 DD / Corsair Carbide Air 240 / 4GB mushkin stealth ram at 1600 / XFX 650W 80+ gold PSU / Kingston v300 240GB drive W/300GB seagate drive / HP x2301 / Gateway KB / Monoprice GM
https://linustechtips.com/topic/850756-display-overclocking-issues/
3 hours ago, SCGazelle said:
What are you using to create a custom resolution?
Nvidia control panel (I have a 1050ti)
37 minutes ago, SCGazelle said:
can you send a screenshot of the custom resolution you set and you Windows Display Adaptor settings.
9 hours ago, SCGazelle said:
hmmm... have you tried restarting your PC?
Indeed
Could it be due to the TN panel? or is that not an issue?
no, that shouldn't have anything to do with this. Windows should at least see the refresh rate. Whether your monitor will work with it or black screen is a different problem.
If you go into Device Manager, can you see any other Display Adaptors? I can't imagine that being the case, but can't hurt to check i guess
Just the 1050
