Ryzen 1400 OC Help
Go to solution Solved by SquintyG33Rs,
12 minutes ago, c00lFD said:
I'm using the stock cooler and auto voltage is keeping at about 1.26v
yeah that's why people can do 3.8 on stock cooler they push the voltage to 1.32 ish and get around 75~80C on load but it's worth it for a 0$$ paid
I built my Ryzen system almost 3 months ago, it's been great so far, but I've decided to overclock it for MAX PERFORMANCE! I have a B350M Gaming Pro from MSI and I'm using the stock cooler. I was able to OC it to 3.6Ghz on auto voltage, it runs at 55 degrees and everything is smooth. Others on the internet have been able to get up to 3.8 at least. So what do I do? Am I just maxed at 3.6 due to the mobo or am I doing something wrong? I have the newest bios installed.
https://linustechtips.com/topic/850375-ryzen-1400-oc-help/
Firstly what cooler do you have? Secondly you shouldn't really be over clocking on Auto Voltage as it can set the voltage too high. You don't want to be putting anymore than 1.4v into a Ryzen, i'd say no more than 1.35v if on air (depending on the actual cooler and case airflow)
Try leaving the voltage at around 1.325V manual and then seeing what speeds you can get
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/850375-ryzen-1400-oc-help/#findComment-10598882
Try to turn off auto voltage.
The MSI B350s are bad, but they should still handle a quad core decently.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/850375-ryzen-1400-oc-help/#findComment-10598887
I'm using the stock cooler and auto voltage is keeping at about 1.256v (This is under load)
https://linustechtips.com/topic/850375-ryzen-1400-oc-help/#findComment-10598915
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/850375-ryzen-1400-oc-help/#findComment-10598957
Download the trial version of Aida64 and use the System Stability Test to stress CPU / FPU / Cache. If your 3.6GHz overclock is stable at 1.26v, then you should be able to run that stress test for at least 1-2 hours without it failing. Personally, I'm not satisfied with my CPU overclock until I can run Aida64 overnight (7hrs) without it failing. I agree with Squinty, though, your stock cooler can probably handle 3.7 or 3.8 at around 1.30-1.35v. As long as your CPU Package temperature doesn't go beyond 80c, you're fine.
CPU: Ryzen 5 5600x  Board: Asus PRIME X570-P  Ram: G.Skill Ripjaws V Series 16GB (2x8) DDR4-3000  Case: Fractal Design Define S
GPU: NVIDIA GeForce RTX 3070  SSD: HP EX950 1 TB M.2-2280 NVME  HDD: Seagate Barracuda 3TB 3.5" 7200RPM
PSU: SeaSonic FOCUS Plus Platinum 750W  Cooler: Noctua NH-U12S SE-AM4  Monitor: Viotek GFT27DB 27.0" 2560x1440 144 Hz
https://linustechtips.com/topic/850375-ryzen-1400-oc-help/#findComment-10598973
