I have an r9270x it's plugged in fans spinning  but no post from the mother board at all. But when I unplug the card I get a post. I'm confused pls halp ;-;.
My build
Idk the mobile exactly but it's a lga 775 socket
6gb ddr3
Evga 80 white certified psu 500 watt
A core2quad
Some hard drives that's it.
https://linustechtips.com/topic/849961-help-pls/
Sounds like you have onboard video? Perhaps that's conflicting with the PCIe video card?
Or, did you not give the video card the power it needs? Forget to plug in the 4 or 6 pin power connector?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/849961-help-pls/#findComment-10594527
Try booting with all chassis fans and HDDs unplugged, but the GPU in. If that doesn't work check for dust, and if you can borrow another PSU and try it out. Also, have you tried plugging in speakers to check for a POST beep? Try clearing the CMOS too.
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/849961-help-pls/#findComment-10594530
This same thing happened to me when i used PCI power extensions, make sure they're securely connected if you have them. Failing thattry and get a different PSU.
Asus Z77 Sabertooth, Intel Core i5 3570k 4.2 GHz, EVGA GTX 780, Corsair Vengeance 16Gb ,
Samsung EVO 250&500Gb, Western Digital Black 2TB,  Corsair RM 750
Custom Water Loop
CPU Block Koolance 380iGPU Block EKWB Clean CSQPump Laing DDC w/ EKWB X-RES 100Radiatiors NexXxoS Monsta 240 & Swiftech 240x35Tubing PrimoChill Primoflex Advanced LRT Elegant White 3/8" ID 5/8" ODFittings White Monsoon Free Centre Compression Fittings 3/8" ID 5/8" ODFans6x Noctua NF-F12 w/Noctua LNA Adaptors
https://linustechtips.com/topic/849961-help-pls/#findComment-10594635
