Hello, around Christmas 2016 I purchased a Razer Blade gtx 970m,
and I have enjoyed using it for around 7 months. Now I have noticed when its charging and I'm heavy gaming (PUBG, CS:GO, Overwatch). The charging seems to randomly switch between 'Not Charging' and 'Charging'. This means the fps drops down to 30 each time and then jumps back up to 60 - 100, and the battery slowly goes down, this can be quite annoying. I have tried changing NVIDA Control Panel settings to Prefer Maximum Performance and Intel Graphics settings.
Can anyone help with keeping the same fps when charging / not charging? Or should I consider buying a new battery / charger? Any answer is appreciated
Laptop Specs:
GeForce GTX 970m
Intel(R) Core(TM) i7-6700HQ CPU at 2.60GHz
15.86 GB RAM
3200 x 1800, 60Hz
https://linustechtips.com/topic/849601-razer-blade-charging-problems-when-gaming/
