why that overpriced 212? ssd is very mediocre.
https://linustechtips.com/topic/848953-build-advice/#findComment-10584056
CPU: Intel - Core i7-8700K 3.7GHz 6-Core Processor  ($389.99 @ B&H)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.89 @ OutletPC)
Motherboard: MSI - Z370-A PRO ATX LGA1151 Motherboard  ($119.99 @ Amazon)
Memory: PNY - Anarchy 16GB (2 x 8GB) DDR4-2133 Memory  ($134.99 @ Amazon)
Storage: ADATA - Ultimate SU800 128GB 2.5" Solid State Drive  ($56.00 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: Zotac - GeForce GTX 1080 8GB AMP! Edition Video Card  ($519.99 @ Amazon)
Case: Deepcool - TESSERACT SW ATX Mid Tower Case  ($39.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ Amazon)
Total: $1350.83
Generated by PCPartPicker 2017-10-20 12:25 EDT-0400
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/848953-build-advice/#findComment-10584058
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($319.89 @ B&H)
Motherboard: ASRock - Z370 Pro4 ATX LGA1151 Motherboard  ($111.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory  ($149.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive  ($78.99 @ SuperBiiz)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive  ($44.88 @ OutletPC)
Video Card: EVGA - GeForce GTX 1080 8GB Superclocked Gaming ACX 3.0 Video Card  ($519.89 @ B&H)
Case: Deepcool - DUKASE V2 ATX Mid Tower Case  ($49.99 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($26.99 @ Newegg)
Total: $1302.60
Generated by PCPartPicker 2017-10-20 12:34 EDT-0400
https://linustechtips.com/topic/848953-build-advice/#findComment-10584075
5 hours ago, herman mcpootis said:
An R5 1600+B350 board would be a better choice at $150 cheaper, plus there's no real advantage to paying for higher clocked memory -- you may as well just buy a cheaper kit and overclock since there's still no guarantee it will run at the higher speeds anyway.
PSU Tier List | CoC
https://linustechtips.com/topic/848953-build-advice/#findComment-10585196
