So I tried to update my PC, it said there was an error, so I copied and pasted the error and clicked on this website https://support.microsoft.com/en-us/help/968003/error-0x80070005-in-windows-update-when-you-try-to-install-updates
did everything it asked (besides malware scan), windows update still didn’t work, so I ran a sfc /scannow, malwarebytes, avast and a DISM /Online /Cleanup-Image /RestoreHealth which was taking a long time and didn’t show the loading lines as usual, so I exited CMD, restarted it and put in the command again. Same thing so I restart my PC and it says preparing windows for update, and I’m confused because on windows update it said there was an error. So I waited it out (15min) and when I came back on all my programs disspeared except for ASUS GPU and the AI Suite 3
here are the error messages that popped up, and the error I had while updating, I also check to see if it couldn’t detect my storage, but I can. My PC specs are in the dropdown menu. Also I tried downloading some drivers for my monitor, that dint work out so maybe it’s that.
one more thing, after I press “ok” for the second image a lot of my programs disappear
Thanks
Quote
"(1) High Frame Rates (2) Ultra Graphics Settings (3) Cheap>>>>Choose only two" Chevaishr
https://myanimelist.net/profile/AnalCavity
PCPartPicker URL
https://pcpartpicker.com/b/bsJ8TW
https://linustechtips.com/topic/848783-bad-problem-with-pc/
1 minute ago, Being Delirious said:
ugh I have had this before, I had to reinstall Windows.
Ok, that really sucks. How should I do it
Thanks
Quote
PCPartPicker URL
https://linustechtips.com/topic/848783-bad-problem-with-pc/#findComment-10582000
