I have been looking for a case to do a custom loop in for quite some time now. I've concluded that I either have to mod a case or go for something like caselabs to get what I want. If I'm going with the 900D from Corsair then I want to replace the whole front panel including the 5,25" bays with a metal mesh or something. Maybe similar to the mesh on top of the case.
Would love to hear some opinions on this and suggestions on how to actually do it.
Desktop Rig:
CPU: i7-6700K  Cooler: Noctua NH-L9x65  Graphics card: NVIDIA GeForce RTX 2080 Ti FE  Memory: Corsair VENGEANCE LED 3200Mhz (2x8GB)
Motherboard: ASUS ROG STRIX Z270i  SSD: Samsung 960 EVO 1TB, Samsung PM981 1TB  Case: Louqe Ghost S1
Monitor: Dell Alienware AW3418DW
https://linustechtips.com/topic/848445-modding-a-corsair-900d/
Photography / Finance / Gaming
https://linustechtips.com/topic/848445-modding-a-corsair-900d/#findComment-10578092
Just now, mok said:
if that full size front panel had holes in it all the way to the top it would have been perfect, thanks for the suggestions
Desktop Rig:
https://linustechtips.com/topic/848445-modding-a-corsair-900d/#findComment-10578094
and alternative:
leave the front panel as is with no modification
you could cut a hole behind the front panel where the 5.25inch bays are to mimic the size of the bottom basement panel
so cut a rectangle slightly smaller in dimension to this dust filter and then use this official corsair part
http://www.corsair.com/en-gb/900d-bottom-side-door-magnetic-dust-filter
i believe its the same spacing
https://linustechtips.com/topic/848445-modding-a-corsair-900d/#findComment-10578252
