my new pc build is getting bsod so I ran a memtest and I got a few hundred errors. noticed my bios was out of date so I updated it tot the latest version ran memtest again and still got errors. so I tried to isolate it by testing each individual ram stick and they both got errors individually and on all 4 dim slots so I'm confused now. I went into the system manager and checked all the drives for updates manually and found that a couple of the chipsets needed updating so I did all of them reset computer and re ran memtest still getting errors but I'm not getting bsod anymore. so do you think I got two bad rams or could it be something else. I have left all setting in bios default. nothing is overclocked. my build is i7700kcpu, 650watt evga psu, asus strix gtx1080ti gpu, nzxt 62 cpu cooler, and 2 x8gb gskill trident z 3200 rgb ram
https://linustechtips.com/topic/847095-need-help/
Seems slightly unlikely both sticks are bad but possible. Run Windows memory diagnostic on them as well and see if you get the same results.
i7 10700k @ 5.1Ghz, 1.37v | Asus Z490-E Strix | Asus Rtx 2080ti Strix | 16Gb Trident Z Rgb @ 3600MHz | Samsung 970 Pro | EVGA Supernova G2 850w  | Corsair 500D | Celcius s36 /w ML Pro's
i7 8700k @ 4.8GHz, 1.31v | Asus Z370-A Prime | Asus Gtx 1080ti Strix | 16Gb Corsair Dominator Platinum | Samsung 850 Evo | Corsair TX 650W  | Corsair 750D | Corsair H100i v2 /w SP-120's
https://linustechtips.com/topic/847095-need-help/#findComment-10562831
3 minutes ago, cl8on said:
curious if it isnt my psu or motherboard pcpartpicker power calc estimated 475 watt though and i gotta 650, another way is if i could swap out parts but i dont have any other parts to swap and test to rule anything else out
650w is plently
https://linustechtips.com/topic/847095-need-help/#findComment-10562860
You're not using an extremely old version of memtest are you? Just trying to roll out things out.
https://linustechtips.com/topic/847095-need-help/#findComment-10562867
If I remember, when you boot to it there should be a version at the top. I would get a new one that supports the new ddr4 memory and controllers.
https://linustechtips.com/topic/847095-need-help/#findComment-10562887
1 minute ago, cl8on said:
it was v1.3
That's from like 2000 lol
https://www.memtest86.com/support/ver_history.htm
https://linustechtips.com/topic/847095-need-help/#findComment-10563000
