I Need Help with Overclocking
Solved by Carclis,
If you've already found your limit in terms of +core clock then you can start altering the frequency curve. You can get to it by pressing ctrl+f. Assuming you don't have the extra voltage limit added your highest value on the curve should be 1062mv but if you maxed it then you should be up to 1093mv. Try playing around with those two points depending on if you turned the voltage to +100% or not and see how far you can push them.
