3 minutes ago, CbrosTheDude said:
Planning to cool a i5 8600k with a bequiet! pure rock slim bk008.
How realistic is it? Will I hav eto upgrade when OCing comes in? (justifying the 'k')
probably upgrade when OC is in the equation if you are going for heavy boosts. This cooler has a TDP of 120W, and the CPU has a 95W, so you wont get too far
https://linustechtips.com/topic/845097-apropriate-cooling/#findComment-10542413
What are your limitations?  Cost?  Space?
i9-9900k @ 5.1GHz || EVGA 3080 ti FTW3 EK Cooled || EVGA z390 Dark || G.Skill TridentZ 32gb 4000MHz C16
 970 Pro 1tb || 860 Evo 2tb || BeQuiet Dark Base Pro 900 || EVGA P2 1200w || AOC Agon AG352UCG
Cooled by: Heatkiller || Hardware Labs || Bitspower || Noctua || EKWB
https://linustechtips.com/topic/845097-apropriate-cooling/#findComment-10542420
I also want to add that, just because the cooler has a TDP leeway of 120W doesn't mean you'll get great temperatures when you overclock it to 120W worth of power. It just means you'll be in safe temperatures.
I've got a Custom Loop Radiator TDP rating of 3,500 watts before reaching good temperatures. Running it with 2x280mm @1600W TDP wasn't getting great temperatures, was hitting 60C. But with 3500W TDP I can't go higher than 40C after maxing out for 2 hours. This is on a ~300W PC Max Load.
https://linustechtips.com/topic/845097-apropriate-cooling/#findComment-10542449
i come from laptop where getting 90C is where you begin to wear earplugs and worry at 100C because it shuts of
https://linustechtips.com/topic/845097-apropriate-cooling/#findComment-10542542
