Trying to find a cheap stick of 8GB 2400MHz SODIMM ram for my new ASUS GL553 laptop so i can upgrade it, but i cant seem to find anywhere cheap in the UK. CEX list the stick for £22 which is a great price (not fussed about being second hand) but its out of stock in all their stores, so im just wondering if anyone has any other recommendations other than eBay becuase its stupid expensive there too? Also, there are different numbers such as 204 or 280, which stick am i supposed to buy?
Thank you!
https://linustechtips.com/topic/844389-ram-upgrade-help/
Ram is very expensive atm
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/844389-ram-upgrade-help/#findComment-10534737
