7 minutes ago, Haden overlord said:
Im building my self a new computer and was wondering if the I should buy the cryorig r1 ultimate or r1 universal. I am worried about ram compat I will be using the G.Skillz trident z rgb kit.
The Trident Z is rather tall, so go with the Universal, I have the Ultimate and it can only fit the Corsair Vengeance LPX DDR4 just nice.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/843707-cpu-cooler/#findComment-10527533
23 minutes ago, Haden overlord said:
Yea looks are important im going black and white but those are not my only options looks are 2nd performance 1st
Unless you are going for highest OC, Dark Rock 3 or H5 would be good option. Both block 1st RAM slot for high profile sticks, but if you are only using 2 sticks, you are fine. With R1 Ultimate and other dual towers heatsink blocks 1st slot too, and fan 2nd. But you can also move fan to other side. Doesn't effect performance, and will give some more room with RAM.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/843707-cpu-cooler/#findComment-10531128
