Hi Guys,
Looking for a solution to fix my issue with my speaker setup for home Hi-Fi.
Currently have a receiver that is both used for music and karaoke but have separate speakers for it but only one set can be wired at once. Does anyone know any hardware that I could add that would allow me to have both sets of speakers attached and be switch by the flick of a switch?
Would preferably like not to replace the reciever
Karaoke is a 2.0 speaker
Hi-Fi is 5.1
https://linustechtips.com/topic/843509-audio-speaker-setup/
6 hours ago, NinJake said:
Need more specs to see the I/O of your environment. But if there's a will there's a way!
so i have two sets so speakers
5.1 and 2.0 system
I was them to all connect up to my reciever which is an onkyo reciever TX5-- something
So i want to be able to quickly and easily change speaker sets without having to disconnect and reconnect speaker cables
https://linustechtips.com/topic/843509-audio-speaker-setup/#findComment-10526564
5 hours ago, elira said:
So i just leave the sub and the two little side speakers attached and just connect the two sets of front speakers up to it? is that how it works?
https://linustechtips.com/topic/843509-audio-speaker-setup/#findComment-10526582
