So long story short after I moved apartments my PS4 was turned on once (and it worked just fine) and then disconnected because I had to redo my gaming PC and the desk.
After plugging it back in it started freezing randomly (sometimes after few minutes sometimes even as short as freezing on the epilepsy alert)
The only fixes I've done so far was rebuilding the database.
Not sure if the software is broken or the harddrive is dying (don't really want to do that as I'm not sure whether my saves are backed up or not)
Any help is welcome :)
Main PC
i7 7820X @4.5Ghz/Asus X299 TUF Mark I/GSkill TridentZ RGB 4x8GB 3000MHz/MSI GTX980Ti Gaming 6G/960 Pro 512GB/850 Evo 500GB/2x2TB HDD/Enthoo Evolv TG/H115i w/HD140s/Corsair HX 850i
Other PCs
i7 3930K/16GB DDR3 1866Mhz/Big Bang Xpower II/MSI GTX 760 TF 2GB/BQ DP P8 1000W/850 Evo 250GB/2TB WD HDD
i5 6600K/BQ Dark Rock 3/16GB Vengeance LPX/ASUS Z170 Pro Gaming/Intel 120GB SSD/GTX 1060 Strix/1TB HDD/Corsair RM650
R5 1600/8GB Vengeance LPX 2666Mhz/ASUS B350F Strix Gaming/ GTX 1050Ti Strix/850 Evo 250GB/1TB HDD/BQ 530W
Notebook Lenovo Ideapad 710S 6500U/8GB/256GB NVMe
Peasant gaming stuff PS3/PS4 Pro/PSP/PS Vita
https://linustechtips.com/topic/842397-ps4-pro-freezing-issue/
I'd hook up the HDD to a PC, e.g. via USB enclosure, and run some drive scans. I'm not sure if you can directly back up your saves from here. If you use PS Plus, your cloud saves should be mostly updated. Regardless if HDD failed or not, I don't really see what else you can do but reinstall PS4 OS.
My stock PS4 HDD failed on me. But it wasn't freezes. It just would fail at installing system updates. I ran diagnostics on the drive on Windows and it failed them. Had to get a new drive.
https://linustechtips.com/topic/842397-ps4-pro-freezing-issue/#findComment-10516387
Sounds like it may be a heat issue. You may still have a warranty, but if you don't I would first try and take it apart and apply some new thermal paste to the APU.
https://linustechtips.com/topic/842397-ps4-pro-freezing-issue/#findComment-10517786
Ok for now it looks like the software was completely broken becase for now all I had to do is YOLO it and reinitiate the PS4 (thank god the saves backed up to PS Plus not like last time) and everything works as it's supposed to :)
Thanks for the replies @StevenMattera @ono.
Cheers guys and fingers crossed it doesn't break again :)
Main PC
Other PCs
https://linustechtips.com/topic/842397-ps4-pro-freezing-issue/#findComment-10518512
