Suddenly no Sound when Monitor is off?
Solved by BOOZy,
5 minutes ago, Plank said:thats the problem. I deactivated my TV and Monitor as sound devices but the monitor just activates itself once restarted...
You can disable the audio device completely in the device manager.
On an nVidia GPU it's called 'NVIDIA High Definition Audio' - under Sound, video and game controllers.
Of course it'll be back on after a GPU driver update or some larger Windows updates, but at least that doesn't happen daily.
