OCed PC won't Post
Solved by iRileyx,
What did you change the multiplier to?
Reset CMOS to reset the OC and you should be able to boot fine then. Either remove the battery or do it with the pins on your motherboard if it has them.
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3 -
8
