Good day everyone, i apologise for my bad English in advance, just got some question regard on ram compatibility on threadripper.
I recently got a 1920X as gift and thinking of doing a build with it, so my question is, will CMK16GX4M4A2666C16 corsair rams work on TR motherboard? ( X399 Aorus Gaming 7 )
While i am not on a budget but i would prefer not to buy new rams ( i am not a fan of those fancy rgb rams ).
https://linustechtips.com/topic/840887-question-regard-on-threadripper/
it is DDR4 RAM far as I can see so yes, I do not know if you will get the max frequency of it, but it is low enough that I would imagine yes, please note faster RAM will make you system faster with ryzen, especially if you are overclocking. But yes it should work, ryzen far as I know does not have the RAM issues it used to have anymore, (TR might be different, but I doubt it)
The owner of "too many" computers, called
The Lord of all Toasters (1920X 1080ti 32GB)
The Toasted Controller (i5 4670, R9 380, 24GB)
The Semi Portable Toastie machine (i7 3612QM (was an i3) intel HD 4000 16GB)'
Bread and Butter Pudding (i7 7700HQ, 1050ti, 16GB)
Pinoutbutter Sandwhich (raspberry pi 3 B)
The Portable Slice of Bread (N270, HAHAHA, 2GB)
Muffinator (C2D E6600, Geforce 8400, 6GB, 8X2TB HDD)
Toastbuster (WIP, should be cool)
loaf and let dough (A printer that doesn't print black ink)
The Cheese Toastie (C2D (of some sort), GTX 760, 3GB, win XP gaming machine)
The Toaster (C2D, intel HD, 4GB, 2X1TB NAS)
Matter of Loaf and death (some old shitty AMD laptop)
windybread (4X E5470, intel HD, 32GB ECC) (use coming soon, maybe)
And more, several more
1 minute ago, hconverse02 said:
It should work fine, but what speed (MHz) are the ram?
2666MHz
http://www.corsair.com/en-gb/vengeance-lpx-16gb-4x4gb-ddr4-dram-2666mhz-c16-memory-kit-black-cmk16gx4m4a2666c16
I think, the name leads me to this corsair webpage
It'll work fine. You'll probably be able to OC too. Just update the bios first.
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
Look at the QVL for the motherboard you want to use. That will tell you if it will work or not.
Main System-
Case: Lian Li PC-O11 Dynamic PCMR Limited Edition
Motherboard: Asus X570 Crosshair VIII Hero WiFi
CPU: AMD Ryzen 9 3950X
GPU: Asus GeForce RTX 2080Ti Strix OC
RAM: 4x16GB (64GB) G.Skill Trident Z Neo DDR4 @ 3600MHz/C16
Storage: 1x Samsung 970 Evo 1TB NVMe M.2 SSD (OS), 4x Samsung 860 Evo 2TB SATA SSD
PSU: EVGA Supernova G3 1000
Cooling: Custom Loop, EKWB Quantum Velocity Copper/Plexi w/ D-RGB Upgrade Kit and Black Frame, EKWB Quantum Vector Strix Nickel/Acetal D-RGB w/ EKWB Strix Backplate in Black, Watercool MO-RA3 420 LT (180-200mm Fan Mount, Classic Black Grill High Version, Wall Mounting Bracket, Heatkiller Tube Mounting Bracket, PCIe Slot Terminal Adapter), Heatkiller Tube 200 w/ EKWB D5 PWM Pump, Bitspower Fittings, 6x EKWB Vardar X3M D-RGB 120mm Fans, 4x Noctua NF-A20 Chromax 200mm Fans, EKWB ZMT Tubing, EKWB HD-PETG Tubing
ITX System-
Case: NCase M1 V6.1
Motherboard: Asus X570 ROG Crosshair VIII Impact
CPU: AMD Ryzen 9 3900X
GPU: NVIDIA GeForce RTX 2080Ti Founders Edition
RAM: 2x16GB (32GB) G.Skill Trident Z Neo @ 3600MHz/C16
Storage: 1x Samsung 970 Evo Plus 500GB NVMe m.2 SSD (OS), 1x Samsung 860 Evo 2TB m.2 SSD (Storage)
PSU: EVGA Supernova 650 GM (SFX)
Cooling: Custom Loop, Watercool Heatkiller IV Pro Black Copper (AM4), Watercool Heatkiller IV RTX 2080Ti Acetal Nickel w/ Black Backplate, 2x XSPC TX240 Radiators, Iceman Cooling Ice P5 Pump/Reservoir Combo, Bitspower Fittings, EKWB ZMT Tubing
