Hello
I have been using windows 10 for a long time and I have got some problems over my time of use
The first one is that I cant open my start bottom or left click it.
my second is that I cant open my settings thought about trying to factory reset it so it is like new.
Those 2 problems were just now, A day ago or yesterday I had a problem that I was getting the blue scream of death saying "IQRL IS NOT EQUAL OR LESS and MEMORY MANAGEMENT" there were more things like this but it stopped after one crash NOTE my pc crash into a blue scream almost 50 times no joke -_- .
plz help the I upgrade my gt210 to gtx960 3 days ago {if it helps anyone}
TY for reading and if you know plz help me been breaking my head.
EDIT - already ran Powershell and cmd nothing work
https://linustechtips.com/topic/840508-window-10-critical-problem/
More likely than not a driver issue, but just reinstall Windows.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Just now, Roye said:
how
Boot off a USB.
SPECS:
don't have one
Then get one. They're like $10 for an 8gb one.
SPECS:
i got a USB stick but i don't have windows in it
So download Windows.
SPECS:
um i don't know how
sorry I'm dumb i can use google if that helps
It's fine, we all start somewhere ;)
Go to Microsoft's website and download the Windows 10 Install Media (or just search Google for it).
Then run it and choose the USB drive you want to install Windows 10 to.
Once you do that I'll help you with the next step.
SPECS:
