Ethernet Won't Work
clear the DHCP table on your router, or just reboot the router.
Intel i5-6600K@4.2GHz, 16GB Crucial DDR4-2133, Gigabyte Z170X-UD3, Be quiet shadow rock slim, Sapphire RX 480 Nitro+ OC, Fractal design Integra M 550W, NZXT S340, Sandisk X110 128GB, WD black 750GB, Seagate momentus 160GB, HGST 160GB
https://linustechtips.com/topic/839128-ethernet-wont-work/#findComment-10478662
The router itself works perfectly fine, all my other devices are connected perfectly, and I rebooted it onces already. I looked it up on google and it looks like I need to download some drivers and some updates for windows 10 but how do I do that without internet?
https://linustechtips.com/topic/839128-ethernet-wont-work/#findComment-10478670
Is this a fresh installation of Windows? If so, the generic Windows drivers may not work. You should get your manufacturer's drivers.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/839128-ethernet-wont-work/#findComment-10478671
1 minute ago, xavu said:
It is a fresh install, but how do I get my mobo's drivers if I don't have internet?
You'll need to use another computer.
Main System: Phobos
https://linustechtips.com/topic/839128-ethernet-wont-work/#findComment-10478686
Just now, xavu said:
Oh right, with a USB right? Gotcha.
No, that won't work. A flash drive or something will. I can't read. Yes, you'd use a USB flash drive to transfer the driver installer to the new machine.
Main System: Phobos
https://linustechtips.com/topic/839128-ethernet-wont-work/#findComment-10478691
