I'm having a low fps on every game like PUBG GTA V  and i have %50 gpu and %50 cpu usage i do everything guys. everything that i can do updating bios, uninstalling drivers, installing drivers, changing os updating everything i build the system again and nothing changes. and i undertand something on gta v when i go outside of the city my gpu usage is on %100 and i'm getting 80-90 fps and when i see a grass when i'm on the grass my gpu ups to %80 and my fps is 80-90 but when there is no grass and when i'm on the city i'm getting 50 fps and my gpu and cpu usge is arround %50-%40 please help my english is bad
my system is:
Ryzen 5 1400@ 3.4 Ghz
16 GB Kingston 2133 Mhz SINGLE
MSI B350 PC MATE
Asus-Dual Turbo GTX 1060 3GB
600W Thermaltake (there is no model on it it comes with case just says the psu have 600w)
https://linustechtips.com/topic/836376-i-need-a-help/
in pubg i'm getting 20 fps in gta 5 inside of the city i'm getting 50-40 fps and i see the my pc specs on youtube the guy getting 80-90 fps on city why i'm getting 50 fps on the city ?
and in pubg same system other guy getting 60 fps and i'm having verry low gpu and cpu usage on every game.
https://linustechtips.com/topic/836376-i-need-a-help/#findComment-10448891
Nvidia control panel> 3d settings i think> prefer maximum performance, windows, power settings, performance mode, if it doesnt fix then idk.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/836376-i-need-a-help/#findComment-10448933
my system is:
MSI B350 PC MATE
Is your ram running correctly? Also go into your GeForce Experience and check if your GPU is being seen correctly. Maybe download the game ready drivers.
https://linustechtips.com/topic/836376-i-need-a-help/#findComment-10449000
you're getting the expected fps considering your specs.
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/836376-i-need-a-help/#findComment-10450357
1 hour ago, atikofx said:
 The guy gets  70-80 fps and %98 gpu usage i'm getting 50 fps and %40 gpu usage do you think i'm getting the expected fps ha ?
He also has a 6GB 1060. Turn your texture quality down a little bit.
Gaming PCs:
Intel i7 4790k, EVGA GTX 980ti, NZXT H440
Intel i5 7600k, Asus GTX 970 DC Mini, Silverstone SG13B
HTPC: AMD Phenom II X6 1045t, EVGA GTX 770 FTW, Fractal Node 604
https://linustechtips.com/topic/836376-i-need-a-help/#findComment-10452623
