CPU: AMD FX 6100
GPU: RX 460 2GB
MB: ASRock 960GM-GS3 FX
RAM: 8 GB DDR3 1600 HMZ
PSU: GIGATECH 550W
Hi recently I bought a rx 460 and noticed the pc is a bit slower, there is a bottleneck between the cpu and gpu, with gpu being underload with 30-40% and cpu 70%. I was playing H1Z1 and there is a some sort of a bug that rises your gpu temperature while in a lobby, this happened on a old card too but with  the rx its not that bad cuz the game crashes at 60 C idk why but it happened once. The other I played h1z1 and the game struggled to load the map and buildings somethimes but the game after it did fine, 20-30 minutes later while I was spectating a friend pc froze with black and white dots idk what they are called but its when those old tv's dont have a signal... you know, and the sound lagged a bit following with a black screen. I rebooted with no problem and a message popped "Windows system recovered from last shutdown and Name of problem: Bluescreen". I updated the gpu driver (optional update) and rebooted and windows was scanning my hard drive that happened before again after pc froze. I  was confused because there was no blue screen at all so what seems to be the preoblem, my os or dying hdd.
Ty for any suggestions.
https://linustechtips.com/topic/836119-pc-freezes-problem-bluescreen/
3 hours ago, Andrelele said:
CPU: AMD FX 6100
GPU: RX 460 2GB
PSU: GIGATECH 550W
Probable the Crappy generic Powersupply
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
Your temps are fine. My first bet would be the PSU or RAM.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
