Looking to build a gaming pc. help me out here thanks :)
would like to use my/harvest parts out of a 2012 dell vostro 260
trying to stay in a low budget
1. Budget & Location
trying to keep the price low but want to be able to run games like ww2 and pubg on higher settings.
Location U.S.A
2. Aim
Gameing, WW2, Pubg, Battlefield, RS
3. Monitors
so far my plan is only 1 monitor and hopefully at least 1080p
need recommendations on good/cheap 1080p 24-27" monitor.
4. Peripherals
already have.
5. Why are you upgrading?
anything is better then my laptop lol
https://linustechtips.com/topic/834469-need-help-with-build/
What parts do you have in your dell vostro? and to run PUBG on high you need a 1060 or a rx 580 min.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429600
right now the dell vostro is stock, besides it has an older nvidia graphics card in it, and i think its i5 dont know how my mhz or cores.
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429613
We need a set budget that tells us how much you're willing to spend.
Just saying "try to keep it low" isn't going to cut it.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429644
2 minutes ago, Ethika said:
between 200-400$
#brokecolllegekid
Doesn't really give us a lot of options... being a prebuilt, I bet that PSU has a ton of proprietary connectors. The CPU should be good enough although PUBG's optimisation is just iffy.
I suggest getting a GTX 1050Ti that doesn't have a PCIe power connector and a SSD if you don't already have one.
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429678
so basically i wouldn't need to upgrade my cpu? just the gpu and get an SSD?
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429690
It's a second gen i5, right? It should be good enough.
For $400, you're not really going to get much... it's just an assumption, but I doubt that prebuilt will give us much options for upgrading due to the likelihood of it having proprietary connectors. But in comparison to building a whole new PC ($400 should only net you a Pentium G4560 with a GTX 1050/Ti), just adding a GTX 1050Ti and a SSD is a much better option.
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429726
Thanks for your input and help!
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429744
Just now, RAM555789 said:
No, PUBG, and BF1 are very well optimized,currently with 8GB I only memory leak on Arma 3 which is not well optimized.
Ah okay, I love how you guys are so noligable about this lol! I know some things but crap lol I'm able to get a lot of answers
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429838
Welcome to Nerd Central 101 were you get better help faster and cheaper than that guy you know from Best Buy
https://linustechtips.com/topic/834469-need-help-with-build/#findComment-10429845
