I'd like to build a desktop PC for around $200 CAD, preferably even slightly lower. I'm not afraid to buy second hand (even if I should be). I'd like a PC I can use for basically everything. I'd like to be able to run everything from my basic word editor to atom with a crap-ton of packages, to light games, to my editing/modelling software. It would be helpful to know whether this is even possible in my price range. I'd like to know what kind of processor and graphics card I should look for. I've found stuff like a thinkcentre with an i5-2400 for $110, but I'm new to this and don't know what exactly will run what I need.
https://linustechtips.com/topic/833782-help-building-pc-~200/
for that kind of money, look for a 2nd/3rd-gen i5 prebuilt with at least 8gb of ram and the best GPU you can afford with the money left. see if you can find a 750ti.
https://linustechtips.com/topic/833782-help-building-pc-~200/#findComment-10422186
PC's that cost $300 or less are best bought pre-built.
PC Build: R5-1600.  Scythe Mugen 5.  GTX 1060.  120 GB SSD.  1 TB HDD.  FDD Mini C.  8 GB RAM (3000 MHz).  Be Quiet Pure Wings 2.  Capstone-550.  Deepcool 350 RGB.
Peripherals: Qisan Magicforce (80%) w/ Gateron Blues.  Razer Naga Chroma.  Lenovo 24" 1440p IPS.  PS4 Controller.
Audio: Focusrite (Solo, 2nd), SM57, Triton Fethead, AKG c214, Sennheiser HD598's, ATH-M50x, AKG K240, Novation Launchkey
Wishlist: MP S-87, iPad, Yamaha HS5's, more storage
https://linustechtips.com/topic/833782-help-building-pc-~200/#findComment-10422944
