6700k - 85% load @ 80C
On 9/8/2017 at 8:42 PM, tgrmst said:OK done a preliminary check and running the game now.
So the PC itself isn't that dusty. Good ole Fractal Design Define R5 filters works wonders. Barely any dust on the heatsink or fans. All cleaned now.
Then I noticed that the Low Noise Adapters were on all this time. Took that out and cranked up the Fan Speed in BIOS to max speed.
Before: Idle 35-40C, regular games 60-65C, and Cities Skylines was 75-80C.
Now: Idle 30-35C, regular games 55C, and Cities Skylines is about 70C (ping max 74C).
I could do more with reapplying the thermal paste. I'm also not sure about fan setting to stay full max speed all the time... I'm worried about leaving back to normal and it still allow temps to go up to 75+C. How should I deal with the fan situation?
Update - I updated my BIOS from a version 8 to 21 (didn't even know there was one since I checked not too long ago).
Looks like the voltages are regulated better and the temps are around 60C (max 65C) in Cities Skylines now. So I guess this is resolved for now. I will keep an eye on it still, but it looks like BIOS updates fixed it.
