Hello, I just wanted to see what you guys think about my build. I am planning on buying it soon and I would be my first pc that I would build. The computer, keyboard, and mouse are on pc part picker. For some reason I cant find the monitors on PC Part Picker so I just left the link on the newegg page. The main things it will be used for is gaming.
PC: https://pcpartpicker.com/list/PdzqvV
Monitor's: https://www.newegg.com/Product/Product.aspx?Item=N82E16824011127&ignorebbr=1
https://linustechtips.com/topic/830855-how-does-my-build-look/
You might want to wait because coffee lake is coming out in the fall and is rumored to be in a new socket so means no upgrade path for you
Also the 850 evo 500gb is only 140
Lastly you won't really benefit from faster memory so you could get a 2400 or 2666 mhz kit and save a little
https://linustechtips.com/topic/830855-how-does-my-build-look/#findComment-10392054
If you can, try to get a 1080 into the build. The cheapest ones cost ~$50 more than the 1070 you've picked. You can get RAM rated at the same speeds for ~$20 less, albeit without LEDs.
I don't know why you chose the G2 650W, but you can get the G3 550W, Seasonic Focus Gold 650W/750W, and G2 750 for $10-20 less. The TXM costs $30 less, if you don't need it to be fully modular.
If you can wait, get the Coffee Lake I7 when it comes out in October. It will have 2 more cores, and requires a different motherboard. The cost should be roughly the same.
https://linustechtips.com/topic/830855-how-does-my-build-look/#findComment-10392088
