Hello guys, so I am a bit confused at the moment with the Internet speed on a global scale "what is a good speed"
The ISP that I have now is.
Downstream:43442 kbps, its like 4.3 megabytes per second.
Upstream     :4999   kbps, its like half a megabyte per second.
Any comment and opinion would be appreciated.
Thanks
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/829569-internet-speed/
12 hours ago, arctek.ltd said:
before that however, what is your subscription speed with your ISP? and the data you have, is that from speedtest.com?
No its data from the router and the several times I checked it
https://linustechtips.com/topic/829569-internet-speed/#findComment-10382687
11 hours ago, mynameisjuan said:
So your 45/5 connection is def good. Standard is 30/5 as about half my customers are 30/5. This just applies to Fiber/Cable. If its DSL, average connection is around 7/1
I am paying for 50/5
https://linustechtips.com/topic/829569-internet-speed/#findComment-10382688
