32 minutes ago, Oshino Shinobu said:
The Fire Stick connects to WiFi itself, not via the TV. Kodi works fine on it without a Smart TV, I have mine setup in the living room to stream movies from my NAS.
Will I need a NAS as well, or will it work just as well with just the firestick and monitor? Thank you for your help!
https://linustechtips.com/topic/828732-kodi-fire-stick/#findComment-10371104
The NAS just stores my media and I stream from it using the Fire Stick, that's just how I use it, it's not a requirement to use the Fire Stick or Kodi.  Kodi will work on the Fire Stick with any HDMI display just fine.
https://linustechtips.com/topic/828732-kodi-fire-stick/#findComment-10371113
Thank you so much
https://linustechtips.com/topic/828732-kodi-fire-stick/#findComment-10371157
