Go for C Java and python they will form a good base.
I recommend geeksforgeeks.org they provide basics and already made up programs.
Once you get familiar with syntax and all you can try solving problems on hackerrank or codechef to test your skills. Go for data structures next then.
You can also look for video lectures on youtube but at a initial level reading and doing is better cos following videos side by side can be tedious for begginers.
You can also see this post
https://linustechtips.com/main/topic/301263-ultimate-programming-resources-thread/
All the best
All the best
6
While I should have included this in the original post, I'll say it now, I've completed learning JavaScript on Sololearn but that means nothing since I hardly understood what was going on throughout the course and don't even remember now. So I'm not really a beginner, I know the basics but I would still have to go through the same sort of tutorials and such that beginners would due to not remembering what I had previously learnt. I know about Syntax and most other terms relating to coding will probably make some sense to me since i've studied Computer Science for a year now.
