So my PC has been running fine for 3 months but randomly it started black screening at the BIOS every other time I boot. I tried taking it out and putting it back in, no dice. I had this problem before and fixed it by taking it out and putting it back in. I tried with some different RAM and no problem. I do not think the RAM is dead, please help!
PC SPECS:
FX 8350
G.SKILL 16GB 1866Mhz
GTX 650 Ti BOOST
ASUS M5A97 R2.0
THANKS!
https://linustechtips.com/topic/82662-ram-help/
If you think that the RAM is good why do you think that the RAM is the problem? Do you have any overclocks?
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/82662-ram-help/#findComment-1128072
If you think its ram take a stick out at a time, and see if thats the issue
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/82662-ram-help/#findComment-1128111
