Hi
I'm not good at English but i hope you guy can understand what i wrote
I have an Acer 5600U it's working normal when i shut it down but when i restart it cannot boot always ask for Ctr+Alt+delete to reboot
when i press Ctr+Alt+delete it still not boot so i have to go to bio setting(do nothing) to save and exit to make it boot to windows every time i need to restart my PC
Please help
https://linustechtips.com/topic/826243-booting-problem/
Your English is fine.
Sounds like maybe a dead CMOS battery? Does the laptop keep the time?
Next time you boot into Windows immediately check the clock and see if its correct, remember that Windows will update the time via the internet quite quickly so you need to check it fast.
Main Rig:-
Server:-
https://linustechtips.com/topic/826243-booting-problem/#findComment-10344567
14 minutes ago, Mc Jerry said:
Hi
Please help
Its a BIOS error try upgrading your BIOS and set your HDD/SSD as Default Boot Device in BIOS. This will definately solve it. If still problem is there then replace your CMOS cell.
https://linustechtips.com/topic/826243-booting-problem/#findComment-10344568
