Ryzen 1600 Temps
Hi,
I recently built a new Ryzen system and decided to start overclocking it today. I'm using the stock cooler and only really need a modest OC until I buy an aftermarket solution. So I manage to hit 3.6 GHz and my idle temps are roughly 48 degrees (Celsius) but when I boot up Prime95 after about 10 minutes I am hitting 91, sometimes even 93 degrees. Anyone else having this sort of issue/ can give me any advice? I am only putting 1.238V (according to Hardware monitor) through the CPU so could the issue be that somehow the stock cooler isn't installed properly or is this just a case of me needing to dial down my overclock? When I was running at stock speeds my CPU was hitting around 73 degrees under load.
I should note I'm overclocking on the Gigabyte X370 Gaming K5.
Thanks
https://linustechtips.com/topic/825964-ryzen-1600-temps/
12 minutes ago, LEDInfinityHD said:
Hi,
Thanks
are you certain that the reported temp is correct? Are you using RyzenMaster for OC?
What are your temps under normal circumstances? Prime95 is a heavy stressor. I would use it if only for stability.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341381
Just now, LEDInfinityHD said:
yes I'm sure, I am overclocking in the BIOS and using both RyzenMaster and Hardware monitor for temp monitoring!
how's the airflow in your case?
System specs:
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341400
Got the Phanteks P400S Tempered Glass with the stock fans at the moment, a 120mm exhaust in the rear and a 120mm intake at the front bottom. Reckon I should move the front 120mm upwards so I get more airflow over my RAM and stock cooler?
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341408
that's not a lot of air at all. I have the same case (minus the glass, much jelly). that air needs a lot more persuasion to leave the case.
System specs:
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341420
I decided to go all out with the TG hehe! Ok what would you recommend? Three 140mm, two intake at the front and one rear exhaust? What's your current setup?
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341427
My setup is a bit odd at the moment, but i'm also liquid cooled so i dont really have the same problems.
280mm rad at the front w/ 1x140mm Corsair SP140L fan at the bottom (for GPU intake), twin 140mm BQ! SW3 PWM fans at the top on a splitter, phantek case fan at the rear.
the reason i have a single fan on the rad is because i broke the SHIT out of the other fan being careless.
System specs:
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341440
240mm rad at the front w/ 1x140mm Corsair SP140L fan at the bottom (for GPU intake), twin 140mm BQ! SW3 PWM fans at the top on a splitter, phantek case fan at the rear.
Not bad at all! Jesus Christ what the hell did you do to that fan!? xD
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341450
SO i was testing on an open bench. I had a GPU that didn't have a fan, just passive cooler. and it was overheating so i thought HEY, i've got a spare fan i'll just let it blow slowly on the GPU's fins to cool it. and it worked... a nice gentle breeze keep it cool.
but then i decided to restart the computer. and i didn't really have it locked down in anything. a pair of books would have sufficed. but i thought that the speed was manageable.
i forgot it went to full speed at startup.
it took off like a planeless propeller and engine. What it ended up hitting, i don't know, but it slammed into something and exploded like a hand grenade.
System specs:
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341474
Oh... my... gawd! I woulda shit myself if a fan started to take off like a bloody plane. Can imagine you weren't a fan of the whole situation (ok that was awful).
Quick update, I moved my 120mm higher up the front of the case and now my max temps at 3.6GHz are a solid 79 degrees which I would say is a damn sight better. Never the less I have some Corsair 140mm AF quiet edition fans on the way!
Thanks for all your help knight :)
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341726
you're welcome. I've got a replacement fan coming from Corsair so the single 140L doesn't have to work so hard. Coolant temp is pretty good at 36.5*C, but RPM is pretty high and i even have the front cover removed so it doesn't have to work so hard and honestly i want the filtration on there. i'm sure you get it.
System specs:
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10341780
I get ya don't worry man. I've just now had issues with microstutter when playing my games :(. Not exactly sure what is causing the issue.... One minute my fps will be perfectly fine (im talking 100+ fps at 1440p here) and then for 1-2 seconds it dips into the 10-40 fps range. Any advice? Temps are all perfectly fine, my CPU usage spikes and GPU usage drops.
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10346525
On 8/23/2017 at 4:40 PM, LEDInfinityHD said:
Hi,
Thanks
Doing this with far higher overclock you either did not fit the cooler properly or the thermal paste is not applied properly.
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10346578
I'll replace the thermal paste and make sure the cooler is on properly then! I'll update in a day or two :)
https://linustechtips.com/topic/825964-ryzen-1600-temps/#findComment-10347006
