I recently just built my new pc using an old hdd (by old I mean like 1.5 years) specs
Amd ryzen 1300x
8gb drr4 corsair vengence lpx
Msi b350m gaming pro
1060 6gb
Corsair VS 450w
1tb wd
Stock amd cooler
Anyway I booted up the pc and it went straight into the bios, I looked at everything it was detecting ram, cpu etc and then I excited it, Just before I exited the bios i noticed something weird my cpu frequency was from deafult - 3.9ghz idk if thats normal or not but anyway I exited the bios and it went to a black screen I investigated and my hdd wasnt plugged in so i turned off the pc and plugged it in to a sata port. After that I am always getting hdmi no signal and my pc wont post. It boots up and the leds come on and fans spin but the caps lock key wont light up. On the mobo the dram debug led is always lit up. I have tried new ram and it still wont post. Any help or info would be highly appreciated. Thanks
https://linustechtips.com/topic/825617-pc-wont-post/
Amd ryzen 1300x
1060 6gb
Corsair VS 450w
1tb wd
Stock amd cooler
Did you try jumping the board? Take the battery out for 30 seconds and put it back in.
If it booted once it should boot again
https://linustechtips.com/topic/825617-pc-wont-post/#findComment-10337924
