Hello
I got a Dell precision t1600, and 2 Different GPU's. And I want to put both on my computer so I can have 3 screens. I now tried for 2 hours just trying to test different things. looked at settings. read online, and nothing worked for me. so do anyone has a clue what to try?  Or if you know if there is a way I could use the ports on the motherboard with the GPU.
I know they both work, tested them in the computer separate.
GPU's
Geforce 210
Nvidia Quadro 600
http://www.dell.com/ed/business/p/precision-t1600/pd - link to the pc
This is a working pc, not Gaming pc, though I should tell you guys that.
https://linustechtips.com/topic/825467-2-gpus-on-same-computer-wont-work/
you do not need both to run 3 monitors
they're probably a combination of nvidia or AMD cards, will not work together usually
or two nvidia or amd cards, probably are not from the same generation or sku, will not work
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
The power supply might not be able to supply enough power to the 2 GPUs. Anyways, you only need 1 to run 3 monitors.
i7-12700k | MSI PRO Z690-A DDR4 | 2x16GB Team Group DDR4-3200CL14 | be quiet! Dark Rock Pro 4 | EVGA FTW3 2070 SUPER | 500GB Samsung 970 EVO Plus | 4TB Seagate Barracuda 5400RPM | Fractal Design Meshify C
LOL, the cards must be the same to run them on SLI or crossfire
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
