13 minutes ago, KevinH9 said:
Ok so I am building a gaming pc and I found this motherboard ASRock Fatal1ty Z170 Gaming K6
fot 75 and if I get a intel or amd board and the CPU is compatbile I get $35 off but I don't know if the intel i5 7th would be better than putting a Ryzen on?
help
I'm having a bit of trouble understanding what you were asking, but I'll give you a response based on what I think you are trying to ask.
I would suggest that you grab a Ryzen CPU rather than an Intel. They are cheaper and perform well in comparison to their Intel counterpart.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334254
R5 would be better over an i5, get a cheap B250 with that.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334266
Just now, KevinH9 said:
But that board had SLI and it's cheap with rebate and $35 off but it's got 3 graphics card slots so I can run multiple Gtx 1050 Ti
You cant SLI the 1050ti, not 3 way with any card with Z270 (Need 8x for SLI). Do you need 3 for anything else? Doesnt the rebate also apply to AMD boards?
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334292
You're kind of defeating the purpose of this thread. It seems you've already made up on your mind about going with Intel. If your plan is to run multiple graphics cards in SLI, and the Ryzen board you selected does not have it as an option, go with an Intel board.
Desktop
Homelab
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334295
Yeah if the CPU is compatible with motherboard $35 off
so the ryzen 5 can I get above 60 fps medium to epic on some games like rust and the forest and Garry's mod?
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334312
Yes, would be better overall than an i5.
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334315
But I'm looking to find out if the intel i5 would be faster and get me better performence and fast fps
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334360
Ryzen is a great all-around performer, while Intel performs very well with gaming. In most cases, the CPU choices (Intel vs. Ryzen) you make will not drastically affect frame rate, and definitely, will not influence the performance of a 1050 Ti.
Desktop
Homelab
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334370
But will the intel i5 will it bottleneck the 1050 ti
Edited by KevinH9
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334378
But win the intel i5 will it bottleneck the 1050 ti
The i5 will not bottleneck the 1050 Ti. It is not a very powerful card. You can go up to a 1080 Ti before seeing any bottlenecking.
Desktop
Homelab
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334391
Ok so I can get above 60 on medium to ultra because I plan on upgrading in the future
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334419
This is very reliant on the games you are trying to play. Could you give me some examples?
Desktop
Homelab
https://linustechtips.com/topic/825293-motherboard-help/#findComment-10334424
