Water cooling?
Go to solution Solved by hammer3339,
A Strix is an excellent cooler, quiet/cool, couldn't see you wringing much extra out of it, what's the reason for the upgrade ?
1 minute ago, DanNeedsTips said:
Does anyone know if there is any products i could use for watercooling a 1080ti Strix gpu? Something like this Corsair Hydro Series H115i only for a gpu
You can use a number of AIO's if you use this mounting bracket:
https://www.amazon.com/NZXT-Kraken-RL-KRG10-B1-Bracket-Black/dp/B00ITTFO8M
Current Build
Successful Builds
https://linustechtips.com/topic/825269-water-cooling/#findComment-10333880
Was just wondering if I needed an extra cooler for it, and water would be good if i needed it. but thank you!
https://linustechtips.com/topic/825269-water-cooling/#findComment-10333924
That's a good case, Be Quiet make some really nice gear. Plenty of room, good build quality, hardware support etc
More or less just comes down to personal taste, anything that will fit the components you have inside is fine. I personally like the Be Quiet line and the NZXT phantoms (have a matte black 630 with some minor customization)
https://linustechtips.com/topic/825269-water-cooling/#findComment-10333965
