I am planning on buying all my parts on Cyber Monday, so i wanted to go ahead and post a topic. I planned and very closely thought out what i was going to buy and these are the parts I finally came up with:
CPU: AMD FX-6300 ($120)
Motherboard: MSI 970A-G43 ATX AM3+ Motherboard ($70)
RAM: Crucial Ballistix Sport 8GB (2 x 4GB) DDR3-1600 Memory ($73)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($55)
Video Card: Sapphire Radeon HD 7870 GHz Edition 2GB Video Card ($145)
Case: NZXT Source 220 ATX Mid Tower Case ($50)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($50)
Total: $563
Thank you in advance for all your advice and suggestions
http://pcpartpicker.com/p/2aRrr
AMD FX-6300 @ Stock, MSI 970a-G46 Motherboard, Crucial Ballistix Sport 8GB 1600Mhz, HIS Radeon Hd 7870 Ghz Edition @ 1100/1350, WD Caviar Blue 1tb, Corsair CX600, NZXT Source 220, and a Benq 21.5 Inch Monitor.
https://linustechtips.com/topic/82481-help-on-600-build/
I'm assuming this is for gaming and your max budget is 600$?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125651
Yes, I could spend a little more, but i am aiming for $600
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125672
For $10 more should i get a FX-8320 or stick with the FX-6300?
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125673
Yeah if you want to go for the 8320 but the 6300 is a fine chip anyways so it doesn't really matter. If you feel it's worth it go for it, especially with more multi threaded game engines coming and with mantle.
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125681
r
I know at one time AMD had problems with some of their higher end FX processors overheating, is that still a problem?
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125690
r
Well they definitely run hotter than intel parts with that TDP of theirs. It doesn't seem like your planning on overclocking because you're using a stock cooler so you'll be fine. Just don't touch voltages until you put that chip under an h100i or an NH D14 or something along those lines.
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125703
They definitely run cooler, max core temp is 65*C.
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125721
Thanks for your help :D I'm going to buy the FX 8320 instead of the FX 6300 and everything else will stay the same
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125744
Thank you everyone for your suggestions and advice :D
https://linustechtips.com/topic/82481-help-on-600-build/#findComment-1125745
