I have x370 k4 and corsair 3200mhz ram. I am currently on Bios 3.1 and memory is on 2400mhz.
- How do I see is my timings set correctly?  Where can I find timings which I will manually enter in bios for specific frequencies (2133, 2400, 2666, 2933, 3200mhz)?
- I read that AMD recommends to turn off BGS and GDM? 1T or 2T?
https://linustechtips.com/topic/824546-help-with-memory-timings/
1 hour ago, Necrodor21 said:
go 3066mhz ram timming
take xmp profile just change the speed leave the timming and everthing else
1t is the default
this mobo cant go higher above 3k
i can do 3.200 but it will have some instability problem (crash there and here)
If I put 2666+mhz bios automaticly switches to 2T. I know that in CPU-Z program I can see my curret timmings but where can I see factory default timmings so that I can compare them with my current? That I will know that everything is OK. What about BGS and GDM?
you dont have default xmp profile?
the turn off button i use :
c6
cool n quiet
cpu boost performance
global p state
none of em has ram's relation
