Hey there everyone, I just bought Battlefield 4 2 days ago on a black Friday sale and am having some issues with the multiplayer (haven't tried campaign yet).
So, I am able to start up the game just like normal and am also able to join a mulitplayer server as well, but after about a minute of playing the game will get REALLY choppy and my frames plummet. Then after a few seconds of choppy frames, the game will go black with the little loading thing( that white, glitchy square) and then the game crashes to battlelog. I've tried to use both the regular launcher and the 64-bit one as  well without any luck. I'm almost positive that it isn't my hardware as its quite up to snuff, and I even tried to use the recommended settings in Geforce experience to no avail. Also I made sure that I have the latest Nvidia drivers from Geforce experience. Please Help and Thank you!
Here are my specs:
CPU: 3570k @ 4.2
GPU: 660 Ti SLI
Ram: 4GB Corsair vengeance
Mobo: MSI z77a-g45
anything else should be in my sig.
https://linustechtips.com/topic/82451-battlefield-4-help/
Your ram is overflowing, 4gb is not enough, 6gb isnt enough. BF4 uses 5gb of ram for me, im not sure about others, maybe try to force it onto 32bit as that caps it to 4gb.
Listen if you care.
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1125441
Here are my specs:
CPU: 3570k @ 4.2
GPU: 660 Ti SLI
Mobo: MSI z77a-g45
It could also just be the game, happens to me a lot, I thought it was my super aggressive overclock, but even now that I have toned it down (1267mhz on my 680) this still happens about once every three games.
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1125481
moar ram
haha, no serious go with 8gb, see if it works.
update motherboard, gpu drivers
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1125665
¸Geforce experience fails.
It recommanded me settings that would surpass my 2 Gb Vram.
anyways I have my own preferences.
PC master race does not need such.
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1127620
I agree, I just thought I would give it a shot.
Yeah, it's actually usefull to a certain degree.
The exemples complete the lack of visual explanation in nvidia contorl panel. By, The time I got my nvidia card I learned most of them trough AMD's Catalyst
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1129863
Ow, did you check if there was a ram bottleneck? is that a single channel or dual channel config?
use task manager to verify Ram Q. usage
for the bandwith, I don't know of any software to verify such.
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1129899
Ok, so I got the Ram and am now up to 12GB and got the latest update for the game, yet I still can't play for more than 2 1/2 minutes before the game crashes.
Then I decided to try and run the game with SLI disabled and it still crashes. Any other ideas?
I think it might just be the game at this point though.
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1148139
well the game is buggy, it crashes on my lots of the time, but i can still get in full games.
i see you got the extra memory, how much hard drive space do you have for your virtual memory,
or do you have a SSD?
My build for this summer, EVGA X79 Dark, 16 gigs Corsair Platinum 1866mhz, EVGA SC TITAN,  2 Samsung 840 Pro raid 0, western digital 1tbhdd velociraptor, 1200 wt psu to be continued :)
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1149890
well, I have my OS on my SSD and the game itself is on my 500gb HDD. not sure if that answered your question.
https://linustechtips.com/topic/82451-battlefield-4-help/#findComment-1152947
