Help!
Downscaling the displayed resolution wont yield much of a reduction in power usage. Allthough fewer pixels need to be calculated every "pixel" is still using the same amount of power.
If you really want better batterylife you are better of opting for a FHD panel, at that distance and size you wont see that much of a distance.
I myself am using a Lenovo Ypga 910 13.9' Laptop with a 1080p screen and it looks really crisp.
I would reccommend you go to a store and try some 4k and HD models yourself and make up your mind if you want mad batterylife or a 4k screen. But if you opt for the 90-something wh battery in the XPS you should get soem decent batterylife even with a 4k screen. It still wont hold up to my Yoga (I get about 8 Hours of Videoplayback) with its 78wh battery.
