DIY LED control question
Go to solution Solved by Unimportant,
4 minutes ago, jacques1mouton1 said:
Thanks for the advice, do you mean like this? (I will only be using 3 LED modules)
The load goes in series between the molex and the transistor, like this:
I picked up a 12V 60mA 3xLED module (picture included). I want to use this with an Arduino nano that will generate a PWM signal with a duty cycle determined by the value of a potentiometer. I simulated the circuit that I plan on using with the results close enough to the required specifications (Tested with a signal generator and a lab power supply set to 12V and the LED module works as expected). What I would like to know, before I blow up my power supply, is if it would be safe to power this circuit from a Molex connector with the 12V going to the circuit and 5V to the Arduino for power. Are there any other precautions that I should take?
This is to illuminate my rear IO panel in the dark but I also want to be able to adjust the brightness. Linus posted a video quite a while back, but there is no way using his configuration to dim the LEDs.
https://linustechtips.com/topic/822793-diy-led-control-question/
@jacques1mouton1
The base-emitter junction of a NPN acts like a diode, so you will need a resistor in series with the base to limit base current. For the given load 1K will be fine. Then you can simply connect the led strip between the 12V molex(led strip +) and the collector of the transistor (led strip -), no additional resistors needed as the led strip includes them.
It is suggested they will draw approximately 1.2 amps per meter at full load at 12 volts you should be fine as long as you provide 12 volts 9 volts can do it but at a cost of brightness
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
6 minutes ago, Unimportant said:
@jacques1mouton1
Just curious do you have an rgb header on your mobo? I have 2 meters powered by my board wrapped my desk with rgb works fine my boards headers are both good for 2 meters that way my desk is synced with the rest of my hardware you can use a splitter to achieve this
20 hours ago, jacques1mouton1 said:
Thanks for the help, will make it like this. (It has been a long while since I worked with transistors and remember very little)
For higher loads you might want to consider using a logic level mosfet like the IRL540. I'm building a 5 channel LED controller for my fishtank. Prototype is done.
mosfet's though require voltage on it's gate instead of a current to open and let current flow.
Here is a schematic that could work for you using a mosfet.
Live example: http://everycircuit.com/circuit/5998474636296192
CPU: i7-12700KF Grill Plate Edition // MOBO: Asus Z690-PLUS WIFI D4 // RAM: 16GB G.Skill Trident Z 3200MHz CL14
GPU: MSI GTX 1080 FE // PSU: Corsair RM750i // CASE: Thermaltake Core X71 // BOOT: Samsung Evo 960 500GB
STORAGE: WD PC SN530 512GB + Samsung Evo 860 500GB // COOLING: Full custom loop // DISPLAY: LG 34UC89G-B
