Help finalizing Ryzen Build.
13 minutes ago, Toyshikate said:PCPartPicker part list / Price breakdown by merchant
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor ($289.99 @ SuperBiiz)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler ($147.20 @ NCIX US)
Motherboard: Gigabyte - GA-AX370-GAMING 5 ATX AM4 Motherboard ($188.48 @ OutletPC)
Memory: G.Skill - Trident Z RGB 16GB (2 x 8GB) DDR4-3200 Memory ($202.99 @ Newegg)
Storage: Crucial - MX300 525GB 2.5" Solid State Drive ($159.83 @ OutletPC)
Video Card: Gigabyte - GeForce GTX 1080 8GB AORUS xtreme edition Video Card ($569.99 @ Amazon)
Case: NZXT - S340 Elite (White) ATX Mid Tower Case ($89.99 @ SuperBiiz)
Power Supply: Corsair - RMx 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($74.98 @ Newegg)
Case Fan: Corsair - ML120 Pro LED White 75.0 CFM 120mm Fan ($24.78 @ OutletPC)
Case Fan: Corsair - ML140 Pro LED 97.0 CFM 140mm Fan ($29.39 @ OutletPC)
Monitor: AOC - AG241QG 23.8" 2560x1440 165Hz Monitor ($486.26 @ Newegg)
Total: $2263.88
Generated by PCPartPicker 2017-08-16 09:36 EDT-0400
Really thank you about the tips and opinions, just so I dont sound like a ignorant prick ignoring some of your advices, let me clarify:
Why NZXT kraken X62? - I bought it at sale for $100
Why the 24'' monitor? - I have pretty small table and this 24" will be just enough, however i switched to said G-Sync model only with 24" instead of 27
Why said motherboard - Same reason as AIO, bought it with $70 discount.
Why not 1080Ti - It is too expensive where i live. Cheapest one is $1000+ and 1080 has stable price while being more affordable. Also i like to pair AORUS with my Mobo
However, once again thank you for the advice about RAM and PSU as it helped me save some money.
Lastly, would a 3.9GHz overclock be stable with this board, cooler and fan setup, with the temps being acceptable?
Thank you once again for much appreciated help.
Have a nice day
No need to apologize ![]()
You should have no problems with the overclock being stable with that board and cooler. Obviously it depends on the silicon lottery as to what overclock you can get. Also temps should be fine. Even the stock wraith cooler can handle a good overclock so a 280mm AIO will easily cope.
