You should be fine on most maps with 60+ fps.
Listen if you care.
https://linustechtips.com/topic/82272-battlefield-4-pc-help/#findComment-1124182
Hey guys!
I'm getting this pc for Christmas and I really wanna play bf4, could I manage it? Xfx radeon hd 7970 3gb VRAM, amd fx 8350 @4ghz, 16gb ram? Could I get ultra at steady 60fps? And maybe dayz at 30+ on whatever settings?
it looks about good for 60fps. though i haven't read any benchmarks for it. though by christmas, mantle might be out so yeah you might get 60fps.
not sure about dayz, don't play that game
p.s welcome to LTT forums!
Gaming/Engineering PC: -i7 6700K, 4-4.2GHz "Eleanor" -ASUS ROG HERO VIII MOBO -16GB DDR4 3000MHz Corsair (2x8GB) -Gigabyte Windforce 980Ti OC edition (1405MHz GPU clock) -H110i GT Corsair CPU Water cooler -980GB Sandisk Ultra II SSD -Corsair 450D ATX Case -RM850i Corsair PSU (Modular) -28” 4K Samsung -27” 1080p Samsung
https://linustechtips.com/topic/82272-battlefield-4-pc-help/#findComment-1124185
Dayz 30+ fps? You should be just fine! :)
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/82272-battlefield-4-pc-help/#findComment-1124188
