PC not working with 360 controller
Go to solution Solved by Guest,
Just now, IAR117 said:
Ah. So would I have to buy a 360 connection dongle?
yes
Just finished installing Asseto Corsa. My 360 controller isn't working at all :/ It connects to the PC and charges but doesn't work even though it is recognized. Have you ever experienced this and what should I do to fix it? I mean racing an S1 around the Nordschliefe is not fun with a keyboard xD Oh and by the way, the 360 controller is a wireless one and uses a charge pack to connect to the PC, though that doesn't stop if from the computer recognizing it. I've also tried different USB ports. HELP
https://linustechtips.com/topic/821957-pc-not-working-with-360-controller/
I believe that method has a lot of issues with properly functioning, as it still treats it as a wireless controller, although it's charging.
