I just bought a power line adapter (hootoo) and i plug in the router to the first one and then the second one to the computer. The 3 green lights are turned on and it says it works perfectly but there is a red x on my connection. Please help. Also I don't have wireless card and i can't run a 50ft cable through my house
https://linustechtips.com/topic/821561-pls-help-power-line-adapter/
1 minute ago, MrMcArtur said:
I just bought a power line adapter (hootoo) and i plug in the modem to the first one and then the second one to the computer. The 3 green lights are turned on and it says it works perfectly but there is a red x on my connection. Please help. Also I don't have wireless card and i can't run a 50ft cable through my house
Mouse over the connection and tell us what it says the problem is.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
Just now, MrMcArtur said:
Not connected, no connections available
Are you plugged into your modem or are you plugged into your router?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
router
Are all relevant Ethernet lights lit up?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
3 minutes ago, MrMcArtur said:
yes, LAN 1 is light up
Have you tried rebooting your router?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
Go to control panel/network and internet/network and sharing center/change adapter settings and tell us what you see.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
43 minutes ago, MrMcArtur said:
It says this folder is empty, basically nothing shows up
Folder? Are you in control panel?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
Also I just moved my whole setup to the router and tried to connect it straight up from the router (no power line adapter) and it still said no connections detected or whatever it says. Is it a problem with my motherboard, windows or my router?
Do you have network drivers installed?
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
36 minutes ago, MrMcArtur said:
No, and I cant install them because I dont have internet. It also says that te driver is unkown... How do I know which driver to install?
Well that's your problem... Use another computer to get the drivers from your mobo manufacturer's website and put it on a usb drive.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
